Make sure you are using the latest drivers for your sound card before proceeding.
For maximum compatibility, we recommend using MP3 files encoded with the Lame encoder.
Fixing and re-encoding files (MP3Converter)
The utility avoids quality loss where possible: if feasible, it only corrects ID3 tag format without re-encoding the audio content itself. VBR is disabled, as we do not recommend its use.
Installation
Download the archive from radiosoft.pro/files/tools/MP3Converter.zip, extract it to any folder, and run MP3Converter.exe.
Usage
Specify the folder containing your files. Enable Search in subfolders if you need to process nested folders.
- Click Check files (without changes) to analyze files without modifying anything.
- Click Run conversion (with changes) to apply fixes.
- Rewrite MP3 tags of incompatible files — updates tags only for files the program identified as incompatible.
- Rewrite MP3 tags of ALL files — forces tag update for all files.
- Rewrite MP3 tags and re-encode incompatible files — updates tags for problem files; if a file remains broken after the tag update, it is re-encoded.
- Re-encode files not encoded with Lame — re-encodes all files not previously encoded with Lame.
- Re-encode files encoded with VBR — re-encodes all files previously encoded with variable bitrate.
- Re-encode ALL files (*.mp3, *.wav) — re-encodes all files to MP3 format.
