To start a specific profile, add /Data="path_to_profile_folder" to the shortcut.
Method 1 — /Delay parameter
Add /Delay=X to the program shortcut, where X is the delay in milliseconds.
Example — RADIO Player Pro, 1-second delay:
Code: Select all
Player.exe /Delay=1000- Remove the program from the Windows startup list (if it was placed there).
- Create a batch file start.bat in the program installation folder (or any other folder — in that case specify the full path to the executable, using quotes for paths with spaces).
- Add the following lines (adjusts the delay via the -n value — number of seconds + 1):
Code: Select all
ping 127.0.0.1 -n 11 > nul
Player.exe- Place start.bat in the Windows startup folder to have it launch automatically on login.
- Open Task Scheduler.
- Click Create Task...
- Enter any task name.
- In the Triggers tab, create a trigger: Begin the task: At log on. Enable Delay task for: and set the desired delay time.
- In the Actions tab, set Start a program and specify the path to the executable.
- In the Settings tab, uncheck Stop the task if it runs longer than.
