Starting the Profile Manager:
- from RADIO AdsMan Pro v.2 - menu "File" - "Profile Manager";
- via the Windows Start menu - RADIO Studio Pro - RADIO AdsMan Pro - "Profile Manager".
- Create - create a new profile. A separate folder is specified for each profile where all its data is stored. The profile marked as "Default" is used when the program starts without a specified profile folder.
- Edit - change the profile name and folder.
- Delete - delete the profile folder.
- Use as main profile - select the profile the program starts with by default.
- Create shortcut - create a desktop shortcut to launch the selected configuration. You can create several shortcuts to quickly start different profiles.
Code: Select all
AdsMan.exe "/Data=D:\Profile_Folder\"
