Stopping after Pause mark
RADIO Player Pro support and discussion
Post Reply
DigiAndi
Novice
Contact:
Post by DigiAndi »
Hello,
if I set a pause mark on a file, the player stops at the end of the file. Now it is not possible to stop the player. I can only push the play button, the fade button can also be pushed but there's no reaction. If i want to stop the player I have to push the play button and then push the stop button. That's cumbersome, because you hear the beginning of the file so I always have to turn the fader on the mixer down an turn it up again when the player is stopped.
It would be easier if it would be possible stopping the player directly.
Greeting,
Andi
Radiosoft
Forum admin
Contact:
Re: Stopping after Pause mark
Post by Radiosoft »
We tested using RADIO Player Pro 1920.
Everything works fine.
DigiAndi
Novice
Contact:
Post by DigiAndi »
I'm also using RPP 1.9.2.0.
The Stop-Button is not active as you can see in the screenshot.
Radiosoft
Forum admin
Contact:
Post by Radiosoft »
Fixed.
Unpack this to the Application folder.
DigiAndi
Novice
Contact:
Post by DigiAndi »
Perfect! Thanks!
Post Reply
