Importing from RADIO AdsMan Pro v.1 (same computer)
Install RADIO AdsMan Pro v.2.
In Settings [ F9 ] -> Configuration in RADIO AdsMan Pro v.2, click "Import configuration from RADIO AdsMan Pro v.1.4.x". The program will automatically locate the data folder from the previous version.
Importing multiple configurations (same computer)
In RADIO AdsMan Pro v.2, create the required number of profiles using the Profile Manager.
Open each profile and run the import as described above. You will need to specify the folder location manually during import.
Moving configuration to a new computer
Install RADIO AdsMan Pro v.2 on the old computer and import the v.1 configuration as described above.
In Settings [ F9 ] -> Configuration, create a full configuration backup archive.
Copy the backup archive to the new computer.
Install RADIO AdsMan Pro v.2 on the new computer and restore the configuration from the archive.
