Sound Glitch on Start fade
Re: Sound Glitch on Start fade
What sound card and codecs do you use?
We've tested your fade settings with the latest Player version (1.9.4.1) under Win7 x64 and K-Lite Codec Pack and we can't detect any sound glitch problems.
Try to Install K-Lite Codec Pack (x86 version is needed due to Player is not 64 bit application).
Codecs can be downloaded from here.
http://www.codecguide.com/download_kl.htm
Any version starting from Basic should suite your needs.
Thank you for your advice.
We plan to make installer which will contain codecs for the end user.
