RADIO Player Pro DSP plugins
RADIO Player Pro support and discussion
Post Reply
Radiosoft
Forum admin
Contact:
Post by Radiosoft »
RADIO Player Pro supports audio processing using DSP plugins developed for Winamp. Multiple plugins can be connected simultaneously, with separate processing chains for on-air broadcasting and retransmission.
Note: not all plugins are guaranteed to be 100% compatible with our products.
Installation
Step 1. Install the plugin
Install the desired Winamp DSP plugin. If the plugin uses DirectX or VST libraries, you will also need a bridge plugin (see below).
Step 2. Specify the plugins folder
Open RADIO Player Pro: Settings → Sound Processing.
In the "DSP Plug-ins folder" field, specify the directory where Winamp plugins are located.
Code: Select all
For example: c:\Program Files (x86)\Winamp\Plugins
Step 3. Add the plugin to the list
Click the "Add Plugin" button and select the desired plugin from the list.
Plugin Configuration
Each plugin has the following settings:
Use for:
  • Broadcasting — process audio during own broadcast playback
  • Retransmitting — process audio during retransmission of an external source
If the same plugin is used for both broadcasting and retransmission, during own broadcast the retransmission processing by that plugin is suspended.
Settings:
  • Show settings on startup — automatically displays the plugin configuration window when the plugin starts. Some plugins require this window to be open to function correctly.
  • Emulate Winamp version — sets a Winamp version number (e.g., 2.20 or 5.666). Some plugins check the Winamp version before starting. Enable only if the plugin does not work without this check.
Processing order:
Plugins are applied sequentially from top to bottom. Audio is first processed by the first plugin, then the second, and so on. Use the "Up" and "Down" buttons to change the order.
One plugin = one instance. If you need to use the same plugin twice, create a copy of the DLL file with a different name. However, not all plugins support this method.
Plugin Management
  • Add Plugin — adds a new plugin to the list
  • Remove Plugin — removes the selected plugin from the list
  • Plugin Properties — opens the plugin usage settings window
  • Plugin Settings — opens the plugin's own configuration window (if supported)
  • Move Up / Down — changes the processing order
  • Restart All Plugins — stops all plugins and starts them again
  • Close All DSP Plugins — completely stops all plugins
  • Disable All Plugins — turns off sound processing by all plugins without removing them
Plugin Types
1. Winamp DSP Plugins
Standard DSP plugins for Winamp. Connect directly.
https://winampheritage.com/plugins
2. DirectX Plugins (via AdaptX bridge)
To use DirectX audio processing libraries, the AdaptX bridge plugin is required.
Download AdaptX v3.5
DirectX plugin vendors: 3. VST Plugins (via VST Bridge)
To use VST audio processing libraries, the VST Bridge plugin is required.
Download VST Bridge v1.6
Common Use Cases
Compressor/limiter for on-air
Connect a DirectX or VST compressor plugin through the appropriate bridge. In the plugin properties, check the "Broadcasting" option.
Separate processing for broadcast and retransmission
Add two different plugins: one with the "Broadcasting" flag, another with the "Retransmitting" flag.
Processing chain
Add multiple plugins and arrange them in the desired order (e.g., equalizer → compressor → limiter).
Post Reply
